04-24-2009 02:08 PM
I want to use the ni5600 Downconverter & the ni5640R FPGA to demodulate an FM signal centered at 433MHz.
Any examples that control both these modules together?
Thank you.
Ajay
04-27-2009 03:07 PM
I would check out the IP Net: http://zone.ni.com/devzone/cda/tut/p/id/4799#toc3 it's repository of examples and FPGA IP, there is a RF and Communications section. As you work through a solution and get problems or have questions, I would suggest to post them as well.
Anna K.
