6008 with 8 channels relay board
Hello!
Is it possibile to use this board: https://www.komputer.de/zen/index.php?main_page=product_info&products_id=582 with 6008 module? To turn on the relay on board, pins has to be shorted to GND on the board (so i can't send 5v from 6008 on PIN). Anyone has idea?
(438 Views)
Hi bonczas,
According to the linked website the board expect "TTL voltage" control signals, so you can use your USB6008 to drive the relays…
(I don't see this "shorten to GND" mentioned on this website.)
(432 Views)
