6024e DAQmx counter data
hello,
I try to use the NI DAQ taraditional example to control my DAQ6024E, but it doesn't come out any data. If I use DAQmx, I can get the data.
Now, I have to use the 6024E counter to control the time event and record the analog data at the same time. I only know how to get the clock data by the traditional DAQ. Since it can't combine with DAQmx, could anyone please tell me how to get the clock data by DAQmx??
thanks
(2,607 Views)
Hi Sai,
When you say "get the clock data," what are you referring to? Can you tell me which example you used to get the clock data in traditional DAQ? Are you referring to the sample clock and number of samples written? Or something else?
Sal
(2,607 Views)
