02-01-2009 07:00 AM
Hi All,
I have posted about this problem previously but i could not get a sufficent answer.My data acqusition card is PXI 6115 and I have TB-2708 DAQ module.I have been trying to get data from a microedm machine actually, the voltage values.The oscilloscope results are ok but I am not able to get the same graph from labview VI.I am attaching the vi i used and the results both from oscilloscope and labview.
The chart in excel file is oscillosope results
And the bit map file is from the labview vi.
As you see the graph taken from labview vi is tottaly different from oscilloscope graph.I do not have any little idea what the reason can be.I have changed the sample rate and the samples per channel values and still no progress.
Any kind of help will be appreciated.
Thanks in advance,
Nazli
02-02-2009
04:49 AM
- last edited on
08-26-2025
03:01 PM
by
Content Cleaner
Nazli,
there are many possible reasons for the issue you are seeing.
I suspect either grounding issues or mismatches in impedances. Regarding the impedance of the 6115, you can take a look into the s-series manual on page 3-15 and 3-17.
Another issue might be a wrong setting in the TB-2708. Please refer to page 6 of the manual of the 2708 for further infos.
What other signal sources can you use to check the correct functionality of the 6115?
hope this helps,
Norbert
