6221 and sc-2350 simulating
I tried to set up in my notebook the NI 6221 multifunction PCI board in simulating mode by Measurement & Automation tool (and it was OK) linking it to SC-2350 conditioning signal box. This last one it was not possible because the tool was searching for one "digitizer" to be be linked to and the NI 6221 board was not available:
Is it possible to configure sc-2350 in Nidaqmx devices in simulating mode?
(3,199 Views)
Hi Fandicolo,
Unfortunately the answer to your question is "No". In fact you have to configure the SC-2350 and when you do it, it is requested to specify a physical device (with "physical" I mean "real, not simulated") into the field "Cabled Device" [see screenshot attached].
I hope this help you.
Have anice day
carlo>
(3,186 Views)
Grazie Carlo
(3,182 Views)
Hello
I am using DAQ card 6221 M & SC 2345 (using 2 input & 1 output channel) integrated in a PXI with controller 8186, in a real time  project using LabView 8.0, the PXI as target and another laptop as host.
The problem is that the maximum sampling rate that I could reach without being late is 1500 sample per second, higher than that it is late uptill 3500 sample more than that there is no output and the late Boolean is not working.
Do you have any explanation for this, that card must give higher sampling rate.
Attached the real time project this project is just for checking the maximum sampling rate.
Waleed
Ain Shams University
(3,036 Views)
Greetings Waleed,
For new questions I would recommend starting a new thread in the appropriate discussion forum regarding topics in your questions. (i.e. multifunctionDAQ and/or RT). This is helpful for documentation purposes and will make it easier for everyone to find solutions because this message subject seems inaccurate for your question.
If you feel like these are related in some way, then please feel free to respond with more details and we can see how to help otherwise we will see you on another forum post.
Have a great week!
Jordan
Jordan Randall
National Instruments Italy
(3,011 Views)
