64 bit application
Wondering if application developed with LV 2012 sp1 with window 7 machine, works in window 64 bit OS envirnment? If not wondering how to develop 64 bit application?
(2,734 Views)
Accepted by topic author ssnp
If the application was developed in 32bit LabVIEW (you don't mention that fact!), it will work on windows 32 bit and windows 64bit.
To develop a 64bit application, you need to build in LabVIEW 64bit and you have the disadvantage that it will only run on a 64 bit OS and toolkit support is limited.
Developing in 32bit is this more universal and typically recommended.
(2,731 Views)
thanks!
(2,723 Views)
