64 bit chaos!
Can someone out there direct me to a link where I can see exactly which toolkits are offered in 64 bit format?
It seems like some toolkits are in 64 bit (Vision, Advanced Signal Processing)... but others are not.
Specifically, I am wondering about:
- Digital Filter Design Toolkit
- Adaptive Filter Toolkit
http://www.medicollector.com
(2,837 Views)
(2,834 Views)
This white paper - https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil... has that information. Those two toolkits are not offered in 64-bit. As a general note for others reading this thread, these toolkits can all be used with LabVIEW 32-bit which is compatible with 64-bit Windows, so they can be used on 64-bit systems, however they will not take advantage of the 64-bit architecture.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Edit* Too slow, oops!
(2,824 Views)
Thanks!
Though very disappointing that so few toolkits are supported.
Here is what happens:
I really want to use the Vision 64 bit toolkit to take advantage of its increased capabilities.  But then my Vision application can't use any other toolkits!  Makes the 64 bit version marginally useful.
(2,818 Views)
