64 bit database connectivity
Hello all,
Let me explain my setup,
My development machine is Windows 7(32 bit), LV2009 and Database Toolkit 2009,
my application reads data on modbus and punches it in MYSQL database.
My Target Machine: Windows 7 (64 Bit),
when i run the application build on 32 bit the communication with DB is not taking place,
does  application built with DB toolkit, visa drivers and main application on 32 bit will work on 64 bit? mainly DB tools
the error is as follows:
Exception occured at in Microsoft OLE
The specified DSN is mismatched in architecture between the drivers and the application.
Shrenik
(3,085 Views)
Accepted by topic author shrekt
I got it by installing MYSQL odbc drivers of 32 bit on the target 64 bit pc.
(3,082 Views)
