6514 digital outputs not working
Hi all,
Its been a while that I posted here on the forum. I was out of touch from labView but recently I started working again. Currently I am working with PCI 6514 Daq card. The card has port4~7 working as digital output ports. Now the problem I am facing with is that all the ports were working fine till suddenly complete port 4 stopper working, soo instead I started using port 5 and then after a while same happend to it. I have been trying to figure it out that what happend but till now it doesnt make any sense to me. My setup is simple, I connect SH100-100-F Cable from the PCI card to the SCB-100 connector block. No external power source or anything. but strangly the ports are not workin...
Best Regards
Regards
Message 1 of 8
(3,739 Views)
Well, it certainly sounds like something is getting toasted. What are these outputs driving?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(3,711 Views)
I am of the same opinion but i am hopeing my hardware is not toasted... soo the outputs actually drive a relay switch which when turned on lights up some lights (20 V) but in the whole circuit I am not sure how can it get toasted ? but most importantly how to get them working back again ?
Best Regards,
Ali Asad
Regards
Message 3 of 8
(3,702 Views)
Do you have suppression diodes on the relay coils? Without them, you can easily fry your digital lines.
Message 4 of 8
(3,697 Views)
The process of getting them working again is easy: buy a new 6514 --- or maybe NI can fix the one you have.
Mike...
LabVIEW Champion
Message 5 of 8
(3,690 Views)
yup actually the card is not working  😞
Regards
Message 6 of 8
(3,648 Views)
How have you been testing to confirm the ports or the card itself (as you mention now) are not working?
Matthew R.
Field Applications & Systems Engineer
Message 7 of 8
(3,623 Views)
Are you driving the coil of the relay directly from the output of the card?  Looks like the card is only capable of 75mA "on all channels"
https://www.ni.com/en-us/shop/model/pci-6514.html
Is it possible that you are driving too much current and causing the life of the digital lines to die prematurely?
Message 8 of 8
(3,617 Views)
