6517B Keithley Stair Case sequence and remain powered ON when reached Stop Voltage
My target
1-Start from zero volt
2-Auto next step may be 5V or 10V
3-Reach peak limit 600.
4-Meter out put should hold at 600V, meanwhile I wil start taking measurements.
Please could you help me in providing/implementing these states. Right now I am going through very hard time to achieve this target.Please provide solution if possible.
Message 11 of 15
(946 Views)
@GerdW wrote:
And please don't spread this discussion over several threads…
If his\her defense, the context of the post was slightly different. Enough for a new post? Maybe... Might as well continue here.
Message 12 of 15
(945 Views)
Accepted by topic author Aashi
Hi Aashi,
@Aashi wrote:
My target
First state: Create a ramp from 0 to 600 with as many steps you need. Use an autoindexing FOR loop to output those ramp values to your device.
Next state: Start taking measurements.
What have you tried?
Where are you stuck?
The message titles express basically the same problem, just using different wording…
Message 13 of 15
(942 Views)
I was using attached VI which is infact stair case ramp up exactly accoeding to my requirement, point where I am stuck how to keep it powered ON once it reaches to peak value say 600.
Message 14 of 15
(932 Views)
I implemented your suggested idea also attaching, its working.
Message 15 of 15
(887 Views)
