6535b 8255 handshake. Setting event and trigger lines.
Hey Folks:
   I'm trying to set up 8255 style handshaking on my PCIe-6535b DIO card. Reading the docs, it seem that PFI 1 is the default Handshake Event line, and PFI 0 is the default Handshake Trigger line. However I see no activity on those lines which makes me think I have to explicitly set those lines. I don't see where I do that. My sub-Vi is attached. If anyone could inform me how to set those lines, I could stop scratching my head as to why there is no activity on those lines.
Thanks.
Andrew
(3,001 Views)
You may get more help in the Hardware Message Boards. I'm assuming you are looking at this manual for the PFI 1 and 0 lines?: http://www.ni.com/pdf/manuals/374373g.pdf
(2,971 Views)
