6584 Output CLK
I am trying to get the CLK BNC to output the clock. I see that it is an I/o port, so it should be able to output.
From looking at the examples, it looks as easy as putting the Io Module_Clock_Out_Enable property in a timed structure of the desired frequency, but when I try that, nothing happens.
Any insight would be appreciated.
Thank you.
Message 1 of 1
(2,421 Views)
