Afraid not. You can run several counter channels simultaneously, but each one needs to be programmed as a unique task.
In certain cases (especially when the counters are performing the same function on different signals), you can reduce the block diagram clutter by putting the config, read, and clear functions in a for loop. You still end up with an array of several unique tasks, but the block diagram isn't much more complicated than it would be for a single task.
-Kevin P.
