660x select PFI pin number.vi
I have recently installed LabView 7 + Device Drivers, DAQmx 9.5.1, and T-DAQ 7.4.4, on Windows XP-32bit OS.  I have 2 PCI 6602 and a PCI 16E-4 cards plugged in.
All devices have been detected properly in MAX.
I tried to execute an old code written in LabView 6.1 (Win2k), but I get an error saying "660x select PFI pin number.vi : subVI is missing".
Can anyone please help me out?  Where can I find this subVI?
Any help is greatly appreciated.  Thanks.
(2,418 Views)
Hi nithyan,
When upgrading to a new version of LabVIEW it's sometimes possible that old code isn't 100% compatible with the new version. It may be that LabVIEW 7 doesn't utilize the 660x Select PFI Pin Number.vi. If that is the case you may have to recode that part of your program.
You could also try checking in the C:\Program Files\National Instruments\LabVIEW x.x directory to see if the VI is there.
(2,398 Views)
