6703 + max + 10401 + error
I have card 6703. I get error 10401 when running "open test pannel" in MAX. I have removed the current driver and re-loaded it from the LabView 6.1 disk. I cannot apply any voltages through this card yet.
(3,071 Views)
Hi
The PCI-6703, PXI-6703, PCI-6704, and PXI-6704 become inoperable when NI-DAQ 6.9.2 is installed from the LabVIEW 6.1 (English-only) CD. The devices do not pass the Resource Test in the Measurement & Automation Explorer (MAX).
The solution is to install NI-DAQ 6.9.2f8. You can download it here: http://digital.ni.com/softlib.nsf/websearch/E6F707598C4FE78E86256B59006BCA56?OpenDocument
Luca P.
Application Engineer
Luca
(3,070 Views)
I have exactely the same problem with pci6703 and nidaq 6.9.3f3. I try with nidaq 6.9.3 from internet. If I have this pb again alse I will try with nidaq 6.8.1 in my possession. It's pitty !
(3,070 Views)
