6x6 MIMO-OFDM System with NI USRP thread coding error
I am newbie in this field. I have tried the 6x6 MIMO example and change it to 2x2 MIMO (by using combination of 4 USRP and 2 MIMO cable). However it occured an error as shown below:
Hope you can guide me regarding this matter.
Thank you.
Rushidi
(3,340 Views)
I have the same error just like you but nowadays , I am using a fully compatible testbed and software but for some reason it shows the same errors . could you find any solution for this case or not , i noted that the post is from 2014 but really i need a help regarding this Issue .
5G Researcher
(2,675 Views)
