7-segment LED
I made a fun 7-segment LED hope people like it:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 9
(24,708 Views)
Hi Harold,
Thanks for the post.
What about this, just using a different font for a numeric indicator?
 I used the font attached below, 7seg. To install the font go to the Control Panel » Fonts, select from the menu bar File » Install New Font and browse to the 7seg.ttf file.
Just a suggestion 😄
Message Edited by Hillman on 05-06-2009 01:57 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 2 of 9
(24,664 Views)
If you want to go with the LEDs (why not, after all, it's a programming execrcise :D), a VI with 7 indicators, a case structure with 10 cases, and 20 diagram constants seems like a lot of (=too much!) code for such a simple task.
A simpler way would be to use a cluster of LEDs and a lookup table, e.g.as follows.
Message Edited by altenbach on 05-06-2009 07:03 AM
Message 3 of 9
(24,642 Views)
I know I ws just making this because I thought it was cool and I was boared lol 🙂
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 9
(24,614 Views)
No doubt, such doodles help your familiarity with LabVIEW and improve your wiring skills. The program even works and does exactly want you want!!! 😄
Keep on wiring! 🙂
Message 5 of 9
(24,604 Views)
Don't forget about the NI Community! Push the example over there so other people can see it when they search for examples.
Jeff | LabVIEW Software Engineer
Message 6 of 9
(24,562 Views)
Hi.. can someone please convert altenbach's VI to the 8.5 version for me? thank
Message 7 of 9
(24,373 Views)
Here you go.
Thanks!
Kind Regards
James Hillman
Message 8 of 9
(24,369 Views)
Jim,
Thanks for the 7-seg true type font.  Loaded it up and works beautiful.  Put a bright magenta background and the contrast is excellent.
george
Message 9 of 9
(21,272 Views)
