8.5.1 Database problem
I just installed the Database Connectivity Toolkit for 8.5.1, and was pleased that the VIs were able to open in 8.5 without having to save upwards (good job)
The problem came when I opened up 8.2 though.  A number of the VIs in the toolkit are saved in 8.5 and/or connecting to the files in the vi.lib of the 8.5 folder (not referenced to <vi.lib>\ but to c:\...8.5\vi.lib)  Anyone else see this problem?
(2,699 Views)
Edit:  It seems the DB toolkit's issue is that it doesn't handle relative paths the best on install, after loading, and getting the 8.5 error a bunch of times, I loaded all the VIs it was erroring on first from the 8.2 folder, then opened my app.  Doing it that way seems to have resolved my problem though.
(Would be an edit, but I missed the edit window)
(2,688 Views)
