8.6.1f1 xcontrol property bug
I believe I have found a bug with XControl properties.  It is illustrated in the attached image.
Selecting the Style property results ina Style ID property node on the block diagram.  I also renamed the property to Color Style, and got the same behavior.  I have not noticed any issues with the other custom properties.
Message Edited by elset191 on 08-11-2009 09:57 AM
Tim Elsey
Certified LabVIEW Architect
(3,171 Views)
I deleted the property and remade it (again as Color Style) and it works fine.  Not sure why I was getting that behavior...
Tim Elsey
(3,156 Views)
I have the same problem now with an XControl written in LV2015SP1 ;-(
(2,758 Views)
There are a set of specific names for property nodes which should NOT be used for custom properties in XControls (like "Label").  I also ran into the exact same problem before where I named a Property and then when trying to access it, got a completely different property (and datatype) back.  It seems there can be some serious name collision issues with XControl properties which are not documented anywhere.
I requested this to be either changed or at least documented before.
(2,748 Views)
