8 AI channel 1MS/s x 10 sec acquire and write binaryfile
I need to acquire analog voltage data from 8 AI channels at 1MS/s for a period of 10 secs and write the data into a binary file. This is a large amount of data and the current VIs that I am using , modified from shipping-example VIs, cannot handle such large volumes of data.
My hardware includes:
A PXI-1042 chassis with two PXI-6133 (32MS/s) S series boards.
The DAQ is connected via fiber optic cable using PXI-8336 MXI-4 interface boards, to a PC with a Intel P4 2.8GHz, 3GB RAM.
I'd be grateful for any help. Thanks.
Philip
(2,764 Views)
Hi Philip,
Kindly post the VI you are using.
Let's see what modifications are needed to make it work as per your sampling rate spec.
regards
Dev
(2,753 Views)
Thanks for replying. I have attached my program. This VI works well for 100,000Hz sampling rate and writes a binary file. However, when I increase the sampling rate to 1MS/s, it gives an error saying that you are attempting to read data that is not there anymore.
The eight channels read pressure transducers and a load cell. So I will have to finally convert the voltage into pressure or force by factoring in a transducer sensitivity. I am not sure how to do that with DAQmx, as it creates tasks and does not give output lines of data. I now do the transducer voltage to pressure/force conversion when I convert the binary to a text file using another VI.
The first part of the VI is just to write a config text file for the variables of the experiment.
Thanks.
Philip
(2,737 Views)
Hi Philip,
Form the first glance i suggest following.
  • Remove 100ms wait you have put.
  • Try to see if you can do away with graph display since that also takes a share of process time to update.
Also i have attached a VI that  i had used for my applications.
(Since your create header.Vi was missing in your attachment, i have put the one i was using for my appilcation. Replace with your VI.)
tell me if this works.
regards
Dev
(2,725 Views)
