8 x PXI 4132 crash
Hi, I am having problems configuring a PXI-1044 chassis with 8 off PXI-4132 SMUs to run a simultaneous voltage sweep, or anything simultaneous. With any more than 5 off SMUs in the sweep the control locks up solid requiring a hard reset, and even then it will require several resets to get the rack to run for more than a minute even just under the OS.
all ideas welcome.
PXI-8106, Vista, LabVIEW 2103, DCPower. PXI 1033 chassis,
Sweep -1V to 1V
<100 points per SMU
100mA
4 off SMUs in each PCI partition.
Running the Reference Example http://www.ni.com/example/31386/en/
Message 1 of 1
(2,763 Views)
