sir what is the procedure to interface and connection with microcontroller 8051 with labview via RS-232 ?
"SB02"
(3,739 Views)
1rst : link your microchip with your computer using a RS-232 cable.
2nd : Program
3rd : Enjoy...
I think your next question will be on the 2nd point. And I will answer to make search on forum about VISA functions...
V-F
(3,735 Views)
You can not connect your 8051 to a RS232 port directly. You need a TTL to RS232 level converter. A very common chip for this purpose is the max232 in some variant. Just Google MAX232. After doing this the rest is up to you as a programmer for the 8051 and Labview. Start simple and build up your competence.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,732 Views)
