81110A - Sweep pulse base level.
Who's know how to sweep the base level of pulse by using hp81110A pulse generator. Actually I already got the pulse generator software but I do not know how to program it using labVIEW in order to sweep the base level of output pulse. Millons thanks
(2,613 Views)
Hi Kie,
Have you installed the driver for the HP 81110A, available here?  Once installed to labview\instr.lib, this will place additional VIs on the Functions Palette which you can use to program the instrument.  As the driver documentation states, you will also need NI-VISA.  The current version is NI-VISA 4.3, which can be found on the Drivers and Updates page.
Jennifer R.
(2,594 Views)
