8920b
Hi I just downloaded the 30day evaluation and would like to know if anyone tried programming an automated test procedures program for agilent's 8920B? Are there examples of programs of the simulated 8920B with driver panel?
(3,111 Views)
You should start by doing some tutorials so you know how to program in LabVIEW. To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
You said you needed an automated test procedure, so perhaps TestStand is what you should be looking at as well?
As for the 8920b, there's a driver for the 8920 (http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=2042), but I have no idea if it supports the 8920B, or even if it's any good.
(3,103 Views)
Thank you for your reply! I am using the book Labview for everyone to bring me to basic level of understanding of Labview for starters.
(3,076 Views)
