903x
903x
(2,110 Views)
@Shivakumar_naganoor wrote:
903x
Use a boolean control and set the "Mechanical Action" property to Latch when released.
(2,070 Views)
903x
Tools > Advanced > Clear Compiled Object Cache...
(2,049 Views)
903x
I'm not sure what your reply is getting at for the OP.  I suspect that you felt like it might have been a joke continuation.
A "903x" is a common SPST physical push button switch with LED of color x that "Clicks in, Clicks out."  It physically has a Latch when Pressed action off-on and Latch when Released on-off.  With the indirect use of a mouse, rather than direct physical contact by the user, Latch when Released is the proper way to emulate the physical behavior of this type of switch with a LabVIEW UI.
My previous reply was simply Calibration of my Magic 8-Ball.
EDIT I guess that should be  Switch When Released!  I'll write up the 8-Ball out of calibration report.
Stop laughing crossrulz! I am having a bad day 😉
(2,037 Views)
@JÞB wrote:
903x
My 8-Ball says its the 903x cRIO series. Anybody want to wager? 🙂
(2,029 Views)
@mcduff wrote:
@JÞB wrote:
903x
Sure,  but the wager must be low and the new, bluebar OP needs to introduce (select any or none pronouns) on a new thread on Breakpoint linked here for payoff.  I may have had a bad day.  And, you have no 8-Ball!
(2,021 Views)
