9213 thermocouple
I'm doing a thermal conductivity lab and I need to know whether the maximum and minimum temperatures listed with the 9213 thermocouple correspond to expected measurements or what can be measured? Thank you for your time.
(2,502 Views)
The 9213 is not a thermocouple.  It is a module which can read them.  Since there are many types of TCs and the 9213 can be configured for most of them (8 types) you can read almost any conceivable temperature.  Read up on the various TC types and see which one suits your app...
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,492 Views)
Given the questions you have posted, I recommend that you first learn what thermal conductivity is and how it is measured. Then study the practical aspects of the measurements, such as the errors in thermocouples and heat loss through paths not part of the measurements.  If you do not understnad these things, it will be difficult for you to even ask the right questions about your measurement equipment.
Lynn
(2,469 Views)
