9219 absolute error
So am I to believe that NI has a module to measure RTD's (that are very accurate) has a "typical" error of  +/- 4.37 °C.
Doesn't that sound excessive?
NI's thermocouple modules are typically +/- 1 °C, I would expect that the RTD stuff is far better ...
I hope you can recheck this for me ... if this is the case then I can not use this module.
If you look at absolute error ... 3.232 ohms + 0.1 ohm = +/- 11.106 degrees °C MAX error
can you please recheck this ... it doesnt sound right at all.
Regards
Chuck
Message 11 of 13
(1,470 Views)
Hi Chuck,
Based on our external documentation for the 9219 - what you are saying is correct. The 9217 is designed specifically for RTDs and is technically a more accurate solution for RTD measurements, however the 9219 is considerably more accurate than our documentation indicates. We were perhaps too conservative in our specs. Email me at logan.kunitz@ni.com because I would like to take this conversation off-line.
Logan Kunitz
Message 12 of 13
(1,434 Views)
It is hard to compare the two. The specs are written completely different for the 9217.
Message 13 of 13
(1,403 Views)
