9264 continuous waveform generation
Does anyone know why my 9264 Analog output module, plugged into a USB-9162 carrier, will not generate a continuous square waves.
Please see the attached .png files.
Thank you.
mgroom
(3,142 Views)
Take a look at the Cont Gen Voltage Wfm-Int Clk.vi. This VI can be found in the Example Finder in LabVIEW Help. Hardware Input & Output>> DAQmx>> Analog Generation>> Voltage>> Cont Gen Voltage Wfm-Int Clk.vi
This produces a continuous square wave using the 9264.
(3,092 Views)
