9326 Phase Difference
Hi
I was hoping I could use the NI-9326 card to measure the phase difference between two frequency inputs
I will need a resolution down to around 80ns, which the card should handle , also the voltages could be quite high which again would be no problem for this card.
However I'm unsure if I can use it.. I have seen some demos using Two Edge Separation to get the change in t between two channels, but if I use NiMax to create the task it doesn't give me this card as an option once I select that type. even though it lets me in the LabVIEW code itself via a property node (perhaps just gives it as a standard option here regardless of task card)
I would really like to use this card as I already have it, so was hoping someone may be able to give me an example on how I can use this card - setting up the channels in the LabVIEW code DAQMx vis
I can use it in a cDAQ chassis or cRIO - so if either is better than the other that's fine albeit would prefer to use it in the cDAQ chassis if possible
Many thanks
Mike
Message 1 of 1
(594 Views)
