A Enum typedef with more 100 entry don't update
Hi!
23516i3AE13A4F973EB194
Same Enum, one made before update the TypeDef (left with 100 items), one made after update (right with 104 items)
Why is not updated even if "Auto Update from Type Def." is active...
Same thing with LV2010
(3,187 Views)
It si OK on my machine.
I suspect the first is not associated with the the type def.
Ben
(3,155 Views)
Try double clicking (or how ever you open for customizing) each control and see if, as Ben suggests, they are both pointing at the same typedef enum. Could happen, have had it happen to me.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,134 Views)
Same tydefctrl. On both case, the Enum have 104 items, but when I recheck the number items aviable, only 100 for the first control.
Just to be sure, I reload LabView and I got the same...
(3,116 Views)
Accepted by topic author CFiset
First, you don't have an enum.  You have a ring control.  It has different behaviors with respect to typedefs compared to enums.
I did a search on "ring typedef doesn't update" and there were a few interesting threads on the topic you should read.
(3,092 Views)
Right, my mistake
Thank
(3,050 Views)
