A.O generate waveform.vi
Please I am interested to get some special functions implemented from a labview library and maked or used from a version of labview .I don`t find them any time and I need them to use for my programs Please Could someone lend me by mail at least the first one?. I only know how to use it in programs,I don`t need or know how to make it
They are:
AO Generate Waveform.vi
AO Continious Gen.vi
THANKS A LOT
(4,990 Views)
Niakko,
I'm not sure I understand you completely, but if you want to get those two VIs, then all you need to do is install the NI-DAQ driver for your OS. Those two LabVIEW functions will be installed along with support for other programming environments, if you choose.
If this does not solve the problem, please reply with more information about what you are trying to do.
John
(4,972 Views)
I have a program that is using the function AOGenerateWaveforms but now I've installed NIDAQmx and then this function can not work anymore. Is there any correspondent function I can use?
(4,129 Views)
