A Table/Listbox with Checkbox Column?
Hello everyone,
I want to build a table or a multicolumn listbox which contains a checkbox
column, is it possible under LabView8.*?
Thanks a lot!
Le
(22,542 Views)
May be the easiest is to create an array of cluster - With a cluster composed of a Boolean (Check box) and a string.
I hope this help you..
Chris
Ah, by the way, everything is possible with labVIEW   : )
(22,538 Views)
I extracted piece of code from application I wrote some time ago. Modify as needed. Cheers [backsaved to 8.0]
LV 2011, Win7
(22,529 Views)
Just FYI: The VIs are still in 8.5.
(22,507 Views)
Woops! So here it is backsaved to 8.0 🙂
LV 2011, Win7
(22,491 Views)
Hi ceties, May I know how you insert the checkbox into column 1. Are you using the symbol or anything else. Thanks, Alex.
(21,547 Views)
Right click on the MCLB and select Visible items->Symbols
Then you have to programatically change the ItemSymbols property and write something into ItemNames. See attached snipet.
LV 2011, Win7
(21,506 Views)
