A Thicker Gauge Needle?
As a relatively new LabView user, I'm a little stumped by some of the uses
for 'Attribute Nodes' and such. Hopefully this isn't too obvious a question:
I would like to programmatically change the thickness of the needle in a
gauge, but I can't find an attribute node selection that lets me do it.
Am I going about it in the right way?
Actually, just being able to replace the skinny needle with a thicker one
in a gauge (indicator) would be enough for my current application. I've
tried the "Edit Control..." environment, but when I try to select the thicker
needle from the "Picture Item" popup in Customize mode, it doesn't do anything!
How do I accomplish this?
Note: just importing a bitmap of a thicker needle is not an option in
this
case -- I need to be able to change its color programmatically, something
that I do not believe I could do with an imported bitmap.
Thanks in advance for any advice!
Justin Goeres
Project Engineer
Indio Systems, Inc.
Pleasanton, CA
(3,539 Views)
The attribute node will not help you any in this case
I tried this also with the same results. My feeling is that this control is
composed
of other controls. The needle being part of a sub control (if you will believe
that).
> Note: just importing a bitmap of a thicker needle is not an option in this
Not sure about this.
(3,539 Views)
Go in the control editor with the control and add a second needle. This
needle will be thick.
Copy the thick needle pict to the clipboard. Undo the changes to revert to a
single needle.
Import the thick needle "at same size" in place of the thin needle. Exit the
control editor.
It is done.
Jean-Pierre Drolet
Scientech R&D inc.
Justin Goeres a écrit dans le message :
38c6a15a@newsgroups.ni.com...
question:
ht way?
thicker
anything!
> Justin Goeres
> Project Engineer
> Indio Systems, Inc.
> Pleasanton, CA
(3,539 Views)
