A Thing of Nightmares. Recommendations when reworking abhorrent code?
@Ben wrote:
he crashes I have seen with diagram clean-up and very bad code, I think there is at about 65535 pixels wide.
Yes, the coordinates are I16 and there is no validation, making things go haywire once you step over the invisible boundaries. Bam!
Message 51 of 68
(1,399 Views)
Seems reasonable. In 5 weeks when threads start arising berating myself and my code, at least you'll know where to direct him! Not to fret though, when he eventually stumbles across the subVI which this thread is about, I'll be the last person on his mind.Smiley LOL
Message 52 of 68
(1,388 Views)
For future reference, how does one quote using the "@User wrote:" for responses? Haven't figured that out yet.
Message 53 of 68
(1,383 Views)
Just press the [QUOTE] Button. (The name will not show in the composition window, but will be there when you post unless you edit way too much in that exact area :D)
Message 54 of 68
(1,378 Views)
Experiment.  The quote button seemed to have had issues for awhile.  I've just ignore it.  Right now they both show nothing before "wrote".  I want to see if it actually appears when I click post.  So there is a bug, but it is just in the editor screen not showing that name.
EDIT:  You're right.  The names do appear with @ after clicking post.  Thanks.
Message 55 of 68
(1,372 Views)
Ah, I see. To be honest I just overlooked it due to it's location. Never even saw it never to the font editing tools.
Message 56 of 68
(1,369 Views)
Well then don't forget to mark the solution!
Message 57 of 68
(1,348 Views)
Just can't help but have that feeling that someone out there is going to see this thread and post a better version of this code they've had stashed away! Smiley Wink
Message 58 of 68
(1,345 Views)
I have actually worked with that exact code before! It had been used for about 8 years before I joined, so I didn't even mess with it. It's ok to leave it as is, it's not like the code rusts over time... 🙂
Message 59 of 68
(1,340 Views)
Glad to see I am not the only one! That is true, if only it became better over time!
Message 60 of 68
(1,336 Views)
