A Variable range depends ON other
Hope Every one would be doing fine.
I came up with an intresting question : I have three Variables on the Fornt Panel,  lets say A,B and C
I have restricted users to  eneter value which is in the range (through Data Entery range Limits) for the Variable A and B
But for the C  maximum range ( data entery limits) depends on the  product of A and B.
User shouldnot be able to enter the value which is higher than the product ,so How shall I impliment this Smiley Tongue
Looking forward.
thanks in advance
(3,409 Views)
use one of this two method for this question
(3,403 Views)
In an event-driven environment an easy solution is to not try to prevent the entry of invalid inputs, but to prevent invalid inputs from being acted on.
Have a value change event for each of our inputs and when one of them is changed test whether that set of inputs is valid. If it is, use it, enable an ok button, or whatever.
If that combination is not valid, don't use it or disable the ok button. You can also put a tip-strip on the last input changed, or the ok button in this situation that says what the problem.
Also, if you have multiple inputs you will often want to have a button that tells the program to accept the new inputs all at once. This is what I have been referring to as the "ok button".
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,383 Views)
Thanks Hate.fouladi for the answer but  i am unable to open it in Labview 2013
And Thank You Mike I got your Idea which sounds good
(3,372 Views)
Accepted by topic author SEMAK
try this
(3,355 Views)
The advantage of the approach I described is that the limit checks can be arbitrarily complex.
Mike...
LabVIEW Champion
(3,347 Views)
Thank you Hate.fouladi and Mike ,Igot an idea It worked .
(3,326 Views)
