A breakpoint has been reached (0x80000003) occurred in the application at location 0x07c79240
Hi everyone,
I got an error when I was clicking around in my program.
The following error message came up:
The exception breakpoint
I don't know but is it possible that it has something to do with an other program that is running on the PC?
It would be nice if someone got a solution or can help me a little bit further.
Hope to hear from you soon.
Kenny
(7,298 Views)
Hi Kenny,
I couldn't find much information regarding this problem. An external search delivered results of different programs bumping into this very same Windows error message. A clean installation (in most cases) was delivering a solution. But first of all;
- how often does this problem appear? Does it appear in Labview in general or in a specific exe / VI?
- which operating system are you using?
- which Labview version are you using?
If it is in a specific VI / exe we can try to strip it down. Does the application use any drivers (DAQmx etc)?
Martijn S
NI Netherlands
(7,241 Views)
