A clip in Voltage while connecting with the Cluster.
We generated an Pulse with the AO(NI9263) of the cRIO9102 we get the frequency of the desired output. But when we connect with the system we have an clip of 2.8V. When we connect with the Function Generator we get it correct with out the clip in the voltage. Is there an way to check the offeset for the AO card pulse.
Message 1 of 1
(2,312 Views)
