[A] cockpit displays
I am searching for cockpit like controls, e.g., an artificial horizon,
compass, and so on.
Does anybody know where to find such controls for LabView?
Bye,
Alexander
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,771 Views)
There are several versions of aircraft style instruments built as Active-X
Controls, I tested some of these and LabVIEW hooks them very nicely with its
Active-X container. Check out one companies product at
http://www.globalmajic.com
Chris
Alexander Salim wrote in message <7kvbbs$ttl$1@nnrp1.deja.com>...
>Hi,
>compass, and so on.
(3,770 Views)
Hi, I am also trying to find an artificial horizon and have also posted on a few forums. Have you had any success and if so could I have the instrument?
thanks
Andrew
(3,533 Views)
Hello!
Since that link posted above is about 7 years old, you might want to consider checking around on the net for something new and good (though I did not follow the link above to see if its been updated).  Also, now have the option of embedding .NET controls too which might help out.
Good luck with the searching!
Travis M
LabVIEW R&D
(3,511 Views)
