A documentation in HTLM
I would like to make a documentation in HTML and open it with my main vi.
Thank you
(3,702 Views)
Try ActiveX of "Microsoft Web Browser". Create Method->Navigate. Wire URL. You are now able to open HTML in it.
(3,702 Views)
(3,702 Views)
> vi.
Another post already pointed out how to embed the document in your
panel. If you wanted it opened in your browser, there is a VI in
help>_browser.llb>Open URL In Browser.vi. There is also one there for
PDFs, if you decide to use those.
Greg McKaskle
(3,702 Views)
If all you want to do is open a separate browser window, look at \help\_browser.llb\Open URL in Browser.vi.
(3,702 Views)
"Emilie" wrote in message
news:5065000000080000003C8C0000-1042324653000@exchange.ni.com...
> vi.
> Thank you
Although others have recommended the "Open Browser" solution, I propose
another.
Look at
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/html/vsconHH1Start.asp
Normal windows programs use this compiled help file. It's a lot nicer than
opening help in a web browser because it uses the standard help window,
provides an index, and provides search capabilities. Labview has VIs for
opening the CHM files.
Check it out. I think the HTML Help Workshop is pretty easy to use and
provides a nice looking result.
-joey
(3,702 Views)
