A error code -63082 in the FPGA
Hello, I had a cRIO 9025, NI9118 chassis, some C modules like NI9234, NI 9862. When I compiled the FPGA.VI and ran it, I found a new Problem as shown below. I do not know how to resolve it. So any help would be much appreciated.
(5,467 Views)
Accepted by topic author Leisure_ksj
Someone else had the same error here (maybe you can review the comments and find something):
https://forums.ni.com/t5/LabVIEW/FPGA-Error-Code-63034/td-p/3241954
Which VI is causing this?  Maybe the FPGA VI isn't being reset properly?
Just to make sure we are on the same page, do you run the FPGA VI directly or is it called by a Host VI?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(5,422 Views)
Thanks for your advice.
I avoid this porblem now by change a little in FPGA.VI, as shown in pictures.
At first, I set Timeout to -1, and the FPGA.VI occured an error -63082 after compiling. Then I changed it to 50 and no error occured after compiling. I do not think this is the reason for the problem. However, I avoid the problem.
I share my experience and I will be appreciated if anybody know the better answer.
(5,398 Views)
Hard to tell why this fixed it but maybe it is good enough for now.  If you have more info and can share it, would be good to give feedback.
ALE Consultants
(5,391 Views)
