03-10-2010 11:26 AM
I am trying to generate a certain wave-pattern with some AC noise on top of it with the software "Labview" for my project purpose. Can anyone please help me why I am not able to generate the noise signal (termed as random in the output window) upto the duration of the signal of the "Noisy_waveform.vi" file. For the reference, I have attached here all the necessary probe points as well.
Thanks & Regards,
Varindra
03-10-2010 11:40 AM
03-10-2010 11:43 AM
Since the duration of the noise signal is smaller than your signal duration when you add the two the result is the same duration of the shorter signal, in this case the noise signal.
03-10-2010 12:06 PM
Please find the vi file attached.
Thanks & Regards,
Varindra
03-10-2010 12:17 PM
03-10-2010 01:08 PM
Hi all,
Thank you. This solved my problem.
Thanks & Regards,
Varindra
03-15-2010 08:17 AM
I need to generate a bin file from vi file (in labview). Can anyone please tell how can I create the bin file. And subsequently I need to import to NI 5421. Will this bin file directly be downloaded into the the card or I need to setup some process.
Thanks & Regards,
Varindra
