A picture as a dialog box
I'm using Labiew 7.0 Express.
I have a good Vi from Ianfung to show a picture on the screen (thank you for this forum to send VIs Smiley Wink ).
I 'd like to do a dialog box with a picture. Indeed: if the size of the picture is 800*600 the size of the dialog box will be 800*600, if 1024*768 it will be 1024*768. In fact I want t borders of the dialog box equals to borders of the picture.
Is it possible to do what I wish?
I attach the VI of Ianfung
labview 7.0
(5,018 Views)
Attached you will find some vi's that I acquired from OpenG.org. I tried doing as you asked and this is one solution that I came up with. It probably is not the best way. But it should get you started in the right direction. Also may I suggest you go to open.org and download the commander.
One more thing you have to put it on the block diagram as a subvi. Had to make a modification
Message Edited by jhoskins on 07-05-2005 06:07 PM
Message Edited by jhoskins on 07-05-2005 06:13 PM
Joe.
"NOTHING IS EVER EASY"
(5,005 Views)
I have downloaded openg commander but some Vis I don't really anderstant how to use it for my application...
Your VI is a good solution.
Thanks a lot.
Manu
labview 7.0
(4,993 Views)
Just keep using them and you will find many uses for them
Joe.
(4,981 Views)
Please find the attached VI useful 🙂
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,974 Views)
