04-12-2007 03:42 PM - edited 04-12-2007 03:42 PM
Message Edited by marek12 on 04-12-2007 03:44 PM
04-13-2007 09:47 AM
04-13-2007 09:59 AM
04-13-2007 01:19 PM
04-13-2007 03:02 PM
02-26-2009 08:51 AM
I know it has been for a while since this is posted. But I am facing the same problem. No more than 4000 points can be written. I am using the latest version of the driver that supports LV7.1. There is a newer version but only has 8.0 support. I am using 7.1 so have no way to verify if it works. Anyway, is there any get-around for this issue?
The attached are the error messages.
Thanks!
02-26-2009 09:43 AM
As I mentioned in the post above, I no longer have access to the instrument. I think that one of the issues was that loading 16000 points took longer than the default timeout. SInce you got a timeout error message, the first thing I would try is increasing the timeout to a larger value. The VIs I posted were used in LV 7.1 so they should work for testing.
Lynn
