A question about comments
>Use a programming style that is self-documenting. (e.g. Don't unbundle the error
>cluster check for "equal zero" to switch a case statement. Wire the error cluster
>directly to the case so you'll get a red/green error case structure. Much more obvious!)
Except for us colorblind folks.  😮  It is still more obvious with "error"/"no error" cases
Sheldon
Technical geek, engineer, research scientist, biodegradable...
Message 11 of 11
(483 Views)
