A question about "Event" structure!
Hellow!
Attached is a simple program about using "event" structure.When i run Event.VI,why didn't Test.VI appear? anyone can tell me the reason? Thanks!
Message Edited by happybird on 06-03-2005 05:08 PM
(2,722 Views)
Right-click on test.vi on the diagram and select "subVI node setup...".
Specify to "show front panel when called" and "close afterwards...".
See if this helps! 🙂
Message Edited by altenbach on 06-03-2005 03:14 PM
(2,713 Views)
That really helps,thanks!
(2,711 Views)
Yes, By default subVIs don't show their panel when called and that is a very good thing! (Otherwise imagine all the little windows popping up when doing some simple calculations using subVIs.) 🙂
(2,706 Views)
You are right!
(2,696 Views)
