A simple challenge Error Bar Plot
Problem is quite simple:
XY1Err1Y2Err2
120.130.2
240.160.2
360.190.2
Plot Y1, Y2 on the same plot showing error bars Err1 and Err2 respectively using the Error Bar Plot function AND (this is the difficulty), make a legend that shows Y1 and Y2 (not the default Plot0, Plot1, etc.).
The key is to make the legend programmatically, dynamically, or whatever you call it, work using the property nodes of the Error Bar Plot function. No fancy coding and work-arounds.
(5,280 Views)
It's amazing what you can do with a search, isn't it?
https://decibel.ni.com/content/docs/DOC-21856
(5,267 Views)
Thanks. I know you're trying to help, but what's amazing to me is that nobody seems to give a simple direct answer.
I have seen that subvi or a variation of it in more than a dozen places. Everybody on this forum seems to direct any legend related question
to the same subvi. I am using the Error Bar Plot, not waveform chart, not waveform graph, and not XY Graph.
You might say, well, what's the difference? The difference is that for my case, the Error Bar Plot plots my Y1, Y2 and the error bars very conveniently.
I have played with create -> property node -> legend (plot name, error bar name, etc. you name it) and have never been able to get this right.
A true answer to my simple problem would be for someone to use the Error Bar Plot, and use the propety node associated with the legend and write a simple VI that will solve my problem.
I am not asking for anyone to do my homework for me. I have played with this simple problem, have searched and searched and searched, and continue to search until I see a simple
solution. Not another link to pretty much the same subvi that I have already seen a million times.
A true answer should look like the simple code that I have attached.
(5,260 Views)
Accepted by topic author murchak
Looks like I answered my own question. Attached is the VI that does exactly what I want!
For anyone (really novices and beginners) who want to plot multiple curves on the same Error Bar Chart with Y-axis error bars and want
the legend to be automatically updated based on user specification, look at my example. See attached VI and the associated data to plot.
(5,242 Views)
Then may I humbly suggest that in the future you say "I've already looked at this example, and others like it, and they don't do what I want because of (a), (b), (c), and (d)". Otherwise, you will get the obvious answer.
And my answer was actually the correct answer. If you look at the subVI that sets the plot names that's exactly what you need to do. Your error is that you are setting the active plot after setting the name. You need to have the Active Plot as the first element in the Property Node list. Attached is the example that ships with LabVIEW, modified to set the plot names.
(5,240 Views)
Yes. You're right. I should have responded with a little more tact, but I was just so frustrated with that simple example.
Thank you very much for the help!
(5,234 Views)
AAAAHHHH!.
Don't create 6 index arrays.  Just take one and drag the bottom border downwards so you can get the 6 outputs you need.  Wire a zero constant to the collumn input of the first output.  The following outputs will get col 1, col 2, col 3, ... by default.
(5,219 Views)
