08-31-2019 01:20 PM
Now for something (related, but) completely different! What if you use the Extended Precision type (whose details are, shall we say, a tad murky)?Altenbach's Floats
You get yet another number! If you assume that the three lowest bits are thrown away (why?), it's correct, but the Dbl representation is "closer".
Remind me to stick with "reasonable precision" (i.e. Biology, not Physics) ...
09-02-2019 11:10 AM
In LabVIEW 2011 32 bit it was I32 limit, not I64:
09-02-2019 05:46 PM
Thanks, fellow LabVIEW devs - this was fun to follow along! 🙂
09-03-2019 05:31 AM
Altenbach's Floats
Hmm, shouldn't Extended precision have more ... precision?
/Y
09-04-2019 04:24 AM
/Y
I'd say in this case it is "as good as"
Bob's comment about the obscurity of the EXT number format is based on this:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/floating_point_numbers/
https://zone.ni.com/reference/en-XX/help/371361R-01/lvconcepts/how_labview_stores_data_in_memory/
Extended-precision floating-point numbers have an 80-bit IEEE extended-precision format.
| Note In some cases, extended-precision floating-point numbers can have a 64-, 96-, and 128-bit IEEE extended-precision format depending on the computer processor. 80-bit is the most common. |
