A simple question about DAQ data sampling
Hi all:
Now I meet a very basic question about DAQ sampling.  I am using NI PCI-6040E DAQ card, SCXI-1001 chasis, SCXI-1102, SCXI1300 terminal block, and SCXI1160 relay module.
I am not sure , is it possible if I want to test a voltage (1 volt) on a resistor. Now I am connecting the Ch0+ to resistor+ (24 volt), and connecting Ch0- to resistor-(23 volt). So the voltage between resistor+ and resistor- should be 1volt.  Actually, It is working at the first, but after I want to test 9 channels based on this connection. The Measurement & Automation can't read data from the DAQ card. (when I test it by multimeter, I can get the voltage data on the Ch0+ and Ch0- of SCXI1300 terminal block).
That's strange, does anybody know what' s wrong about it?/
Thanks a lot
(3,201 Views)
Besides, When I used a battery to test it, the data sampling is fine??
I am just curious what' s problem about it?  float??
(3,184 Views)
Hi hanwei,
According to the specifications of the PCI 6040E (page 3), the input signal and common mode voltage should never exceed 11V from ground.  I believe this is the reason you are able to measure the potential of a battery but not the 24V signal (even though the differential value is only 1V).
Best Regards
Hani R.
(3,152 Views)
