A single block of code with and without loop.
Hello!
I was wondering if there is way to include a single block of code with and without a while loop. Basically based on enum user select if they want the program to run continuously or not. By using a case structure all the graphs, controls are replicated and I want only one of each . I don't want to use a ab control I want the user to select the option from an enum or ring.
Hope the question makes some sense.
Thank You.
(808 Views)
You are not making a lot of sense.
All you need is a simple state machine to cover all possibilities.
A case structure does not require duplicate graphs.
For more specific advice, attach your code draft.
(792 Views)
You place the while loop and if you don't want it to loop you wire True to the Stop node.
Qestit Systems
Certified-LabVIEW-Developer
(741 Views)
@bilalskd wrote:
Hello!
Thank You.
Where did you learn to make word salads?
(703 Views)
