A strange IP address was allocated when NI MAX runs
I have a sbRIO-9632 with a nano router connected to it by wire, which was configured to client mode and has a specific IP address (192.168.0.103 both from itself and from the host router. However when I run NI MAX a different IP address(192.168.0.100) appears and I cant connected to the board in roobotics setup wizard.
Help, anyone?
Thank you
Orit
(2,430 Views)
Ok I've noticed another thing, The board (it is a part from  robot Dani starter kit 2.0) is connected by his MAC address instead of its router MAC address and probably that is why he gets a different IP. How can I change that?
Thank you again
(2,427 Views)
Have you tried to connect the sbRIO of the Dani directly to your computer?
(2,377 Views)
